Front Pads.
trials4life1
which pads do you lot use on the front for a maggie?
with a grind?
I love my rockman with CNC backings, they are not brilian for the rear but front is superb! The best front brake I ever had. But quite noisy!
Edited by 3dd
It seems like most people use a smooth rim on the front. The front brake tends to work better than the rear anyway, because it encourages the bike to lift up when you pull it, if you see what I mean.
Well it always depends what you are doing. I like light grind on mine. It also takes less energy to lock the front, especialy helpfull when on rocks.
Tar sucks, I'd consider it a last resort. If you put too much on it sticks, if you use too little it's useless, and it goes funny in the wet.
Brake spray isn't great either, I knew a guy who used it, it used to wear off really quick.
so whats the best combo for front
  • 3 months later...
I've found the exact opposite. At the moment I run them F+R. Mine are crazy good on the rear, but not brilliant on the front. Not sure why, but they never work properly when I need them to.
