Hope Lever Sticks In
Dan S
Today when I was riding, i found out that my lever sticks in a bit, after I push it.
I thought It might be because of the pads...they seemed to act "Sticky" as well.
How can that be solved?
Edited by Dan S
Lube the lever pivot and the brass barrel, a tiny spot of normal oil will work fine. Could also be that the lever pivot bolt is nipped up a bit too tight, used to afftect the old levers, not sure about the newer ones.
Im not sure a siezed caliper piston would affect the lever return action, it would certainly make the pads drag on the disk though.
it doesnt have to be a seized caliper piston, could be the lever piston thats seized
