Hydraulic Rim Brakes
hawkesy226
bought a Da Bomb trials bike just a cheapy to start practising on, have the cash to buy some hydraulic rim brakes just not sure wich to buy and how to bleed.
looking to get some HS33's Got around £40-50 for a pair bidding on ebay :D
is there much difference with the HS33's to the HS11's?
and is water bleeding have better results then magura royal blood.
and wich pads are better?
really new to magura's
i had hs11s before but they kept leaking for some odd reason, hs33s i have had no problem with,
yeah a water bleed is better as it is more quicker,springy response, this is because it is thinner that oil, seeing as winter is coming around if you want water i would advise mixing it with anti freeze stuff, mouth wash etc.
