Having Trouble Getting Bolt Off For Front Tyre
dooie97
heey guy
well i have got my onza rip 2009 and i'm trying to get my for tyre and rim off but the bolt is jammed
how could i get it off?
i have tried my friends dad tools and his dad could not even get it off so please can you try give me tips to try get it off
thanks.
Which bolt?? The one on the axle?
it the one to get the hole wheel to get off it's about 16.5 mm bolt
http://www.tartybikes.co.uk/product.php?product_id=2228&category_id=61) it the bolt in this pic
can u tell me what the bolt is called
is it rounded?
yes a little but even when it wasn't it was still not coming off :/
Edited by dooie97
It won't be a 16.5mm will either be 16 or 17 but I'd assume it's a 16mm.
What have you been using to try and get it off? May be worth taking it to a local garage and just asking them to have a go with a decent socket and long ratchet for a decent bit of leverage. Shouldn't be that tight, best make sure the thread is greased up when you get it off before you refit the wheel!
cheers mate your a great help thanks and it well tight lol :turned::turned:
  • 2 weeks later...
could be the cones coming loose, try lightening (away from the frame towards the hub) the black bits that sit on the inside of the hub, i don't have paint on this computer but if someone wants to make a diagram that'd probably help :D
