Jack Meek Clips
JackMeek
nice riding there jack, am using phatpads and find them brilliant, do you use a booster on the rear of the limey 3 and what grind works best, i've found since i have put a booster on the brakes don't bite aswell.
My booster is integrated with the bike. Booster should not create a negative but less fade out from power absorb in the frame. The brake needs all things perfectly setup to get it to bite like crazy. Pad alignment, strength in the rear chain stay, booster, perfect bleed, longer brake leaver, clean grind more conditioned than deep, true wheel and some phats. Weather conditions can effect the brake bite after cleaning and drying so it's allways worth cleaning the surface of the pads and recondition rim with a light grind.
cheers jack, yeah i have the limey 3 with intergrated booster but i've went and put trialtech 4bolt on aswell. i use phatphluid plus phat pads, long lever , medium grind etc brakes are really good just wanted to know your set up as they sounded pritty deadly.
thanks for info much apprectiated.
Deadly at the moment touch wood they stay that way. Im loving it.
