Limey 1 Crank Or Chain-Ring Problem
Cresswell_d
Hi all!
I got a limey 1 of a friend a couple of days ago.
Ive just started to build it up with parts from my other bike. (t-rex)
The problem is the chain-ring is is hitting the frame has anyone had this had the same problem?
The problem is either:
My b.b is too small. (I've measured it and its about 127mm.)
or,
My crank set up is too big. (Ive got a 20 tooth chain-ring on a threaded bash ring.)
Can any one help me please
Thanks
Darren
Trouble is, 127mm bb is the longest BB, so really you could only fix it the other way, get a smaller sprocket on the front.
I run a hope pro 2 on the back and that is a 15 tooth.
Do I need a 18 on front or do I need even smaller?
If I do need smaller what is the idea ratio?
