Sexy Koxx Silver Sky
Franksx2005
Frame and Forks
- Frame: Koxx Silver Sky
- Forks: Try-All Forxx Prototypes
Wheels
- Front hub: Try-All H Disk hub
- Rear hub: Try-All H Disk Hun
- Chain tensioner: Try-All Snail Cams
- Front rim: Try-All Hole Black
- Rear rim: Try-All Hole Black
- Rim tape: Try-All
- Front tyre: Try-All Sticky lite
- Rear tyre: Try-All Sticky Lite
Brakes
- Front brake: Hope Try-All Mono Trial 160mm rockman super light rotor With Kevlar hoses and carbon lever
- Rear brake: Hope Try-All Mono Trial 160mm rockman super light rotor With Kevlar hoses and carbon lever
Drivetrain
- Cranks: Try-All ISIS
- Freewheel: Echo SL
- Chain: KMC Kool
- Rear Sprocket: Try-All Screw On 12T
- Pedals: Echo TR Caged
- Bottom bracket: Try-all ISIS
- Bashplate: Koxx XTP
Steering
- Headset: Echo SL
- Stem: Try-All 3D Forged
- Grips: Trialtech Foam
- Handlebars: 2011 Try-All Karbon
Nice mate i was close to buying it before you but decided it was little bit too steep for a second hand sky. Looks even better with them bars personally i would do the forks black aswell would look soo much better. Anyway enjoy!
Oh and what you doing with the speedrace now?
I almost stuck the black trialtech forks on it but then decided i like the white. i thought its a bargain for one that is as good as new, ive never seen one go that cheap! Im loving the black wheels!
A friend of mine has offered me 600 for it. it has had a small crack welded on it.
