Onza Zoot Magura Hs33
Herrarge
Maguras usually come with the adapters as standard. However tarty dont do this. They sell them with just the brake, thus giving you the chance to choose the clamps of your choice. I infact have the exact piece of kit you are looking for, for sale in my sales topic.
Well i have a rear HS33 with Evo 2 setup (modified) on my Zoot 24". Its not an easy setup at all, this is because the gap between the Vee posts is much wider than the Evo 2 adapter can take. I had to adapt mine (luckily i am an engineer by trade and have all the tools to hand) i had to cut the adapter in half and add an extra bridge to gain the wider width. It works well but was a pain in the arse even with all the tools and the workshop i had to hand. If i was you (as mentioned above) i would get a good Vee set up with a booster and some good pads, will save you so much hassle... ;)
