Anyone Own An Onza Pro (2010)
BradJohnson
Im about to purchase a new bike and the onza pro 2010 has taking my liking, im just wondering if anyone on here owns one and cant tell me honestly what they like and dislike about the bike, and im a little causious about duel disk trials bikes so can you tell me a little more about what they are like too.
Thanks Brad.
errr from a beginners point of view great starter bike however you'll wanna swap the discs round so it's 180mm on back, instead of the 160mm they give you, although you'll need new/different caliper mount things....then change to rear maggie when you get good ish
So are the brakes no good, i have saw one for £280 second hand and i thought that was a bargain but i might be ables to strech a little more and go for the blade or the comp.
Edited by bradjohnson
So are the brakes non good, i have saw one for £280 second hand and i thought that was a bargain but i might be ables to strech a little more and co for the blade or the comp
oh wait, i had the pro 2009, but the 2010 brakes are the same, the bike is perfect for a beginner, the only things i can see wrong are: the pedals aren't very grippy at all you'd be better taking out one of the cage walls, and then the brakes can be made to be amazing, but, on the rear of the bike you need a stronger brake, now, you could get a 180 mm rotor (either buy one,swap it with the front or steel it)and put the 180mm rotor on the back but you may also need to buy another caliper mount that's a different size (this will cost you about £15-25, and it's only be done when you're good enough to balance get up stuff and you want to start to back wheel hop. on the other hand when you get ready to back wheel hop by a magura set up which will cost you around £60-80 for a new one and a decent set of pads.
I can already pedal kick, i have been riding a year :giggle:, i'm wanting the new bike to get my self into a few comps, probably at novice/intermediate.
In that case I wouldnt, most of the bike will end up being upgraded.
Yes true, but if i get something modern like the pro, I wont need to upgrade it as much as say 07 zoo python, basically all as i'll upgrade, it tyres if it needs them and brakes.
