BradJohnson Posted June 9, 2012 Report Share Posted June 9, 2012 So, on my onza limey the chain rubs on the frame, and its rubbed its way through quite far. How can I sort the chain line so it doesnt rub? If I put another spacer behind the freewheel to push it closer to the bottom bracket will this work. Thanks. Quote Link to comment Share on other sites More sharing options...
stunt man t Posted June 9, 2012 Report Share Posted June 9, 2012 (edited) you need a rear sprocket with the teeth in the middle and not on the edge, like this one http://www.tartybike.../c73p10709.html you cant flip the sprocket you have because the chain hits the spokes a lot of the 'pro series' frames do this Edited June 9, 2012 by stunt man t Quote Link to comment Share on other sites More sharing options...
ooo Posted June 9, 2012 Report Share Posted June 9, 2012 If I put another spacer behind the freewheel to push it closer to the bottom bracket will this work. yeah, you may have to do this as well as changing your rear sprocket, I think its to do with cranks usually having a bash ring. Quote Link to comment Share on other sites More sharing options...
CalRobbo341 Posted June 9, 2012 Report Share Posted June 9, 2012 I filed my old frame and then it stopped, havent rode since then though so yeah ^ the above! Quote Link to comment Share on other sites More sharing options...
TrialsIsHard Posted June 9, 2012 Report Share Posted June 9, 2012 I had this problem on mine, getting the freewheel off is a b**ch so I'd change the sprocket first I have a trial tech one and it works like a charm Quote Link to comment Share on other sites More sharing options...
