V-Brake Help
Laurence--Trials
I've finally got all the bits to get my v-brake working but Im not sure about a few things and i've got a TINY piece of the spring missing.
First off the tiny piece thats missing:
The bit that goes in that tiny hole has gone missing, its apart of what makes the spring work. Is there anything i can use instead of it? I think i needed a new one any way as it was bent before i even used it. Are they available to buy anywhere?
I thought about cutting up a small pin and cutting off the spike and using that instead, would that work?
Sorry for the bad picture, but between the two gold bits (bolts) you have the main v-arm. Under that you can see a decent sized space between the v-arm and the adapter, should that be there or not? i get a little bit of play (up and down from both arms.)
Great.. i assume you mean a pin from a chain? its about dubble the size i need :( i'll ask at work tomorrow.
Thanks, what about the wobble?
She means try to look at CRC :giggle: Little wobble is normal for arms,some just do it more.What arms you have?Shimano last wobble free longer than avids in general.
Edited by ghostrider88
Try making a replacement spring using an old spoke.
Could be a nice temporary fix while you set about locating a new one.
Good shout, i'll try that tonight.
My bad haha, long day at work ;) Okay thanks :)
http://www.chainreac...x?ModelID=82074 My Pauls don't even use that hole, so I might not be much help. This might work with some modification though.
Edit: Looked at it a bit more and I don't even know if thats for a vee brake.
Yeah im not sure it is either, dont know what it is..
