RockMan Radix
Matthew_Gibson
Was in two minds about if I should keep it or go back to mod. I'll see how things go! Still not 100% bang on. but it will do for now.
Spec for those who can read ;P
FRAME - RockMan Radix V1
FORKS - Neon HS-33 and disc
HEADSET - Echo SL
BOTTOM BRACKET - Trials Tech Race
CRANKS - Echo TR 170mm
FREEWHEEL - Echo SL
REAR WHEEL - Echo Urban/Echo Hub - Schwalbe Fat Albert
FRONT WHEEL - Echo Urban/Onza Hub - Schwalbe Black Jack
STEM - Rockman10x30
BARS - Trials Tech High Rise. Foam grips
REAR BRAKE Magura HS-33 2005, 4 finger lever. Water bled. Trials Tech splitter. TNN Green in CNC'd backings. Echo TR Brake Clamps
FRONT BRAKE Magura HS-33 2004 2 finer lever. Water Bled. TNN Green in CNC'd backings, Echo TR Brake Clamps
CHAIN - KMC Z510 HX
SNAIL CAMS - Try all Smooth
  • 4 weeks later...
