How To Remove
Jang
Go to LBS.
Ask them to remove your cups.
Takes 10 seconds, should be free.
If youre lazy:
Big flat-bladed screwdriver and a mallet - tap round gently and slowly from the inside of the head tube.
Easy peasy :-
thats what I did tap with a flat haeded
swrew driver works fine :D oh and if it does not come
out cover it in wd40 and it will eventually :D
  • 2 weeks later...
  • 1 month later...
when I bought my planet x it diddn't come faced (didn't know it at the time). I took it down to halfords, and they cocked it up even more, now its araldited in but it is a Pig headset, so hopefully should be sweet. Newbies - check your headset is properly faced
who put your headset in the first place?
  • 5 months later...
What does faced mean? (Y)
Also when putting in headset cups do you grease them where they go into the head tube?
