Rear wheel wobble!
Brian Bleech
7 hours ago, Adam@TartyBikes said:
All I can think of is a bust bearing or a snapped axle... But you have ruled that out. Hmm. Got the thin washer between the freehub bearing and the hubshell bearing?
It definitely isn't the axle, I think the washer is there, it wouldn't work without that, would it? The wheel is working fine otherwise.
1 hour ago, BJ. said:
Are the bearings sat all the way home? Did you use a freehub tool to knock the freehub seal in?
First time, no. When I did it second I used all the proper tools, could dismantle it and put it together again.
