Fork length for 26" bike..
megamomac
Hi guys, any advice for how long a set of forks should be to suit a frame with  60mm BB rise? I've got two choices at the moment. 400mm and 440mm from centre of dropout to bottom of fork crown.
The 400s seem ok and the 440s seem high but just as comfortable to ride.
Any thoughts?
Most 26"  trial frames are designed around a 400-410mm axle-to-crown fork.
An A-C from 440mm is either for a DJ bike or an old 26" cross country mountain bike.
For each 20mm more, your head tube angle decreases of about 1 degree. The bottom bracket height increased from about 7-10 mm.
I think it is important to have a steep head angle in trial. It helps when beeing on the front wheel.
Thanks for the info!
