Hope tech evo lever leaking
laurent
Hi everyone !
I bought from you a few years ago a "Hope tech evo" lever (https://ep1.pinkbike.org/p4pb9311179/p4pb9311179.jpg).
For a few weeks, maybe a month it leaks some break fluid from the two reservoir "caps" .
Having some spare diaphragms, i tried to change them. And it still leaks. Not a lot, the break is useable.  But it does worry my in term of reliability.
Anyway, what do you think of it, it is a known issue ? And what spare part could i swap/change to solve this issue.
Thanks a lot !
It is a small amount. If i wipe it off before riding, general usually it's not there again after that.
But if y let the bike stays stored a few days there is a small amount of fluid again.
See on the picture attached, it seems to come from around the screw holding the caps .... hence the rust ...
I ride it like that for weeks now, but if there is a problem i'd like to know and fix it. And if there is no problem, i much more happy then ! ;-)
