Help With Crank Tapers
Dr. Nick Riviera
well mny cranks have chewed tapers ( square ) so that the crank wont sit level on the bottom bracket it raises slightly , about 2-3 cm at the pedal end ( am i making sense? )
so i thought to file out the chewed taper and do the coke can bodge , but this hasnt worked very well so do i keep on filing or is there another solution ?
dont say get new cranks as i cant at the moment
any help / ideas?
thanks in advance
If its that badly rounded, whatever bodge you do, it isn't going to last long. Your just going to have to get some more cranks. (Even though you cant).
Damn trials and it expensiveness!
(Y)
any help / ideas?
thanks in advance
Which side? If it's non-drive side, Halfords STOCK some real cheap crank arms for about £6 (Y) If it's drive side you have to order them in I think. If you can't find that amopunt of money and blag some tools, I'd be amazed.
From what I can remember they are made from plastic coated steel, too. When my bro was broke I got him one to get by... it's still on there 6 months later!
This topic is now closed to further replies.
