Brake Fluid On Pads
Watson©
Right Lads/Gals
I got brake fluid on my EBC Red's ( Basically brand new ) for my Mono Mini and it soaked all the way thro... is there any way I can get the fluid out so that my pads are normal again... and nobody say file the pads because all that will do is take of the top layer and not remove the fluid from the whole pad.....
Help >_< B)
Watson
Right Lads/Gals
Help >_<  B)
Watson
Soak them in Muc-Off for a few hours or something?
Corish
BURN THEM ! ! ! AAHAHHAHAHAHAHAAA
But on a more serious note, you can actually burn them, hold them over your mummy's hob or something, make sure you open a window though as it smell's ! hehe......
If you find the pads are still contaminated then just burn them some more.
And yes, this does actually work >_<
Only a few minute's, that should do the trick. But if you put them back on and they are still a bit crap then just do it for a little longer. Just make sure your holding them with some pliar's or something, i wouldn't want you to burn your finger's.
