Braze On V-brake Mounts?
011001000110010101110010
Chop the old ones off, and fix them back on?
I doubt they'd 'exist' as a standard part, since all frame tubes are different shapes. Just rob some of another frame :P
You can get V brake ones from ceeway, thats where I got mine from.
www.ceeeway.com
I wouldn't bother brazing them mine were tig welded fine :P
EDIT: I have some cutoff pashley forks somewhere.
Edited by rich4130
Thing you mean an anchor plate. DMR make them - you take the U brake mounts out (unscrew them) and fit this plate, which has the mounts in the right place for V brakes.
As for the mounts, when I re-welded my Pash forks for my 24" wheels, all I did was carefully cut down the original weld - or around it as much as you can to prevent you cutting too deep and damaging the forks/frame - threaded a 5mm bolt in there and used it as a lever to break it off, tidied them and the forks up with a file and a flap disk on an angle grinder and re-used them. Easy as long as you're careful :P
I supose i have one for sale.
Its a big horse shoe thing that you "jubily clip" (i think thats what they're called) onto the frame. I have one laying around i dont need anymore.
:ermm:
