Your Rear Brake Setup
Michael Hardman
Lever: Magura 04
Callipers: Magura 04
Hose: Black Magura
Bleed with: Magura blood
Mounts: 2bolt evolution
Pads: Heatsinks
Rim: Alex DM24 + Tar
Booster: Standard magura 2004 booster
Edited by Dylan_
Brake - standard Magura Hs33 (sth around 2003 year) even never rebleeded
Mounts - 4 bolts
Pads - Plaz CRM
Rim - 7 years old DX32 (or Megamo, I'm not sure), smooth, with tar
Booster - Echo 4 bolts (not Control)
Wel done that man, its taken long enough for someone to question the point of this thread.
Anyway it just alittle survey of what people use.  Theres alot more v brake users than I thought
ahhhh i see....
maybe if people would give little comment of the brake, it would be more helpful :(
Mine is......
Lever: Standard Magura with CNC'd lever
Calipers: Standard Magura
Hose: Magura black
Bleed with: Water
Brake mounts: 4 bolt
Pads: One Plazmatic CRM and One Koxx Bloox (original one)
Rim: Onza Ronnie with a medium grind
Booster: none
your only running the pads like that because of me (Y)
Hose: Goodridge
Bleed with: Water
Rim: Echo CNC with worn out grind
Booster: none
used to work well with a harsh grind but its loosing pwoer now
Lever: Magura 2004
Hose: Venhill red
Bleed with: Water, really badly, has air in
Pads: well over a year old koxx bloxx
Rim: Ronnie with old worn otu grind and tar
Booster: Shimano XTR
It works for me, can't be bothered in making it better.
Cylinders: magura 2003 HS33
Lever: magura 2003 HS33 w/o cnc lever
Hose: standard magura black
Booster: steel standard & outland alu V booster
Pads: plazmatic CRM
Bleed: standard magura blood, only rebled once
Rim: Onza ronnie with grind/worn and maybe tar. depends how i feel and the weather.. it all works amazing.
So basicaly everything standard apart from pads. Feels amazing.
Sam
I have two (Y)
Avid Ti Arms
XTR Lever
Odyssey Cable
Plaz Crv's
XTR Booster
It looks rather worn now though, that pictures nearly a year old.
It worked better than the magura, without the modulation though, but it cost so much money, and the calipers wear out really fast when paired up with a really grabby pad like CRV's.
Its all good when new, can't fault it, but constant cleaning, cable replacing, and general maintainence is time consuming and expensive.
That setup cost £75, But I dread to think how much I've spend on cables, a replacement set of arms, and now the pads need replacing. My magura cost me £22.50 complete..
