Mini Experts
that NBR dude
Hey all
Im wanting a new exhasut for the mini. Something like a Maniflow large bore 2.5 ect ect. My main worry is, I want a centre Exit on the clubman as it will look so much cooler, but being an estate, can you fit a standard centre exit exhaust to an Estate with the longer wheelbase?
If all else fails, I can just get an Estate/Van side exit, but I really want to try and get a centre exit exhaust for looks.
If anyone knows please help >_<
currently scanning minispares.... ive had a thought....
BUGGER!
i was hoping, that the estate/van link pipe would be straight, and the side exit kink would be on the rear back, but looking in this pic http://www.minispares.com/Product.aspx?pid=38079
it would appear that the link pipe has the kink....
obviously your going to need a stage 1 kit.... and a decent LCB manifold....
although i would seriously suggest you DONT get a real stage 1 kit, and buy the parts seperately, as there are very few stg 1 kits that use decent quality bits!
a way around your problem, would be to buy yourself an 1 3/4'' saloon system, with your desired large bore centre exit tail pipe....
and also a straight through, 1 7/8ths link pipe....
cut the link pipe, leaving a section around 18'' long. leave one end untouched, but cut 4 slots into the other end, around 4'' deep each.
slide the normal end onto your LCB's Y piece and clamp up as normal. then, using LOTS of fire gum, and " clamps, facing opposite each other, slide the end of your 1 3/4'' system INSIDE the 1 7/8ths pipe, and clamp it up at the desired length
the slots will allow the larger pipe to close around the smaller, and if you have a good amount of fire gum in there, and dont squish it out of round, it will give you a perfect seal and you will be able to choose what length exhaust you want!
all for about an extra £14 over the saloon system-get the saloon system you want, and a mild steel (none of this stainless rubbish!) link pipe is around £14!
alternatively, just do it the other way round if you decide to go for a 1 7/8ths system, using the 1 3/4 pipe form the y piece!
either way.... if you want something a bit more permentent, get the two link pipes, set the length, and weld it around! job done!
either way andy, theres not really any more than an extra 30mins work over fitting any other exhaust!
just make sure you dont drill into your fuel tank when fitting the back box :) youll need to put two new holes in the subby :)
