Posting Frames
nb88
Yo guys......i need to post a frame off and i have bubble wrap and some cardboard i got from sainsburys :P ... i was thinking just cover it in bubble wrap as best possible then wrap the cardboard round it and tape it all up like a biatch.....how do you guys usually send them? I dont have the right size box.
Go to halfords, steal :P" a bike box which they chuck out, modify the box slightly to make it smaller, so it passes for an acceptable size.
You can send it by Royal mail, standard parcel (3-5 days About £10) or Parcel force next day £17 or 48 hours £13, they will also pick it up from your door.
Phil.
Get the boxes which never get used any more, and some scissors, start with the rear triangle, then do the top-tubes and down-tubes and work your way to the bottom bracket/seat tube. Lots of tape is required, and if you can, get someone to help you, I'd imagine it saves 1/2 the time as I found it was a bitch doing it on your own!
You can get it exactly to the right size and hopefully save a bit on postage costs :P
Example:
