Harsh Grind
An_toin3
hi people !, could you explain what you mean by harsh grind ? mine are always light grind ! no matter how hard I put on the grinder ! it still gives the same result ? :'(
Could someone explain how to do a harsh grind ? :D
Will try and get a pic of my grind so you can see !
Thanks
An_toin3
ok, a new grinding disc is always a good start
its not really how much pressure you apply when your grinding, but its the angle you grind at, if you hold the grinder at a steeper angle to the rim then it will grind into the rim more than over it hence giving you a harsh grind
be extra carful when applying a harsh grind as its very easy to get carried away and demolish the rim
cheers :'(
Another question.., when i throw myself backward the brake is slipping and you can hear a "swoosh"? is it normal ? because when i'm going normally ! the brake is very powerful !doesn't slip at all :D
going like this : "-->" = very strong !
like this : "<--" = Not strong at all.. swoosh sound!
Thanks
An_toin3
Does it work well?
My grandad has an angle grinder, but he has really put me off using it - he said that it cuts through bricks like cheese and that if I try I will cut my wheel in half!! (Im not that great with my hands - maybe he has a point!)
How easy is it to slip up and cut your rim in half / gouge a big chunk out. My grandad thinks its inevitable, is it really that bad?
My grandad has suggested taking a wire brush to the rim and thinks that will roughen up the surface? A good idea?
How did you find it an_toin3?
Thanks
~Gaz
Does it work well?
Thanks
~Gaz
i use an angle grinder..., just don't be afraid ! don't push to hard on the grinder and everything should go well ! (Y) don't really know how to explain this :P
Does it work well?
Nah, to get a decent grind you have to press pretty hard. There is no danger of grinding through your rim unless you go nuts.
I always do my grinds totally 90 degrees to the rim, as in straight down on it. This i find gives a grind that works both directions very well. There are loads of topics on what disc to use so you can search them out, but I find the best way is to go to home base and buy a couple of different ones and try them yourself. They are only like 70p. I prefer to use a metal cutting disc.
Also a tip I would give is to do it fast and hard. If you spend to much time on one area it will end up making it smoother rather than rougher. So I press real hard and run it over the rim quickly. But again you have to play about your self to see what works best for you.
Dont worry about damaging your rim. They have loads of sidewall and grinding (even harsh) doesnt take that much off.
And Im not even sure how hobbsie managed to do that to his rim, but luckily for him its a mavic.
Also if you grind at an angle not 90 to the rim then one direction will always be weaker.
Edited by JIX
it doesent matter how you grind you rim, it will always work the same backwards as it does forwards. this is aslong as you use the same method for each side.
its to do with how the pads are set up and how the pad material rubs off onto the rim.
Will
Hey guys!
I got my grandads grinder out today and had a nose, it is so loud :P I had a headache afterwards! I had a quick practise on a piece of metal he had lying around.
Im going to get a new metal grinding disk soon and then go for it later this week :) Just need to order some new pads in first - Koxx Reds I thought would be good...
On a side note, whilst I was there I made myself a "hop-o-meter" :) It looks decent enough ;)
Thanks for the advice,
~Gaz
