Freewheel
emery
ENO is the best freewheel out there. That's undeniable.
But the best set up is a profile freehub. (aka hub with a built in freewheel). So you have the 'freewheeling device' on the rear and a fixed cog on the front.
Both a good setups, depends how much money you want to spend/got.
Could be fun with a front and rear freewheel though...
Think how easy it would be to fakie etc... ;)
It would be exactly the same to fakie with two freewheels than one. :'(
Sorry for not being clear but its my front ( I thought i have a freewheel ) and what cranks are good aswell.
toby :">
ENO then, there's only 2 freewheels worth thinking about, ACS and ENO. The ENO is £80ish, opposed to the ACS which is £13.
Crank: Zoo or Tensiles. :D
Edited by JT!
Id rather get the acs as ineed it quick
thanks
Well get it from select bikes and it's welded up for you. :'(
Mind you you probably have an ACS already on your bike.
Edited by JT!
what bike you got?
If it's a mission i don't know what freewheels on it, but it's on the back so chances are it fine as it is. Freewheels on the back get alot less forse applied to them.
So what cranks have you got at the moment?
It dosn't really matter weather you have the UCI bashring or not, and you have the bashplate anyway, so i supose you could get the uci bashring one to help stop your trousers getting caught, but it's just extra weight.
EDIT: Hand on i'm confused now, do you have your freewheel on the front or on the rear? Have you got a pic of your bike, that would make it much easier.
Edited by JT!
At the moment I've just got basic muscle man cranks same as a t-pro. I don't know what a freewheel is really but I think it's chain ring I don't no I'll try and post in a pic
I dont know how but it's just a basic one you get on a t-lite probally.
sorry for the confusion.
toby (Y)
^ Freewheel
It's the device that lets you pedal, but when your going down hill, the back wheel spins without the pedals going round.
Quite sure yours is on the front, so you need to get the tensiles without a chainring.
These
or
These
If you after the tensiles.
However, tensiles are ISIS (splined) so your going to have to get a new bottom bracket. As the bottom bracket you have now is square taperd. Pics below.
Square taper.
ISIS (Splined).
So if you don't want to buy a new bottom braket, you have to get some cranks like this. They come in both ISIS and square taper.
(Y)
That clears it all thanks alot and If the cost arn't to high I will get a newbb as i need one anyway
thanks (Y)
Edit: why cant I get a chain ring with them
FSA Platinum ISIS would these fit in the bb hole bottom bracket
toby
You don't need the chainring as you exsiting freewheel just screws onto them.
Any 128mm BB will do. I think tartybikes has some but they arn't on the site.
Right I'm getting some tensile crank arms and a try-all bb and a acr freewheel does this sound good with some dmr v8's
toby :)
NO!
Try-all bb's don't fit into t-lite frames. The middle section gets stuck in the parts that's not thredded. ;)
You want an FSA DH bb, but i had problems with mine, but i think if you got a differt model you should be ok. I hear that tartybikes have them in, but they arn't on their site.
Edited by JT!
The only BB i have come across that fits into a t-lite frame is the FSA's. But when i had my fsa the freewheel rubbed on the bb sell. But i have a feeling it maby was just an odd ball.
So yeah, once you have the bb sorted the rest is easy. I bought a Truvativ gigapipe DH 128mm BB and it didn't fit untill i took the file to it, and it went in perfect.
I would go for the fsa's, cheaper than the try-all one anyway, and they'll fit. :)
I would go for the fsa's, cheaper than the try-all one anyway, and they'll fit. (Y)
yeh olr the standard onza ones :)" .
get an eno acs are poo when out yesterday and my mates skipped on every hop he did .
eno eno eno eno eno.....or profile but i like the feel of the front freewheel and its lighter :)" .
so yeh eno or prifle dont bother with acs if you value your life.
cheers
dameon
