Problem Please Help
Control-Trials
Hi all i was just wondering if somebody could help me, right ive just been trying to set my wheel upand i ride 26 inch by the way with a quick release and for some reason once i have put it in line and then i do 1 learch on it and it come's out of line could someone please tell me what the problem is and tell me how i need to sort it.
www.freewebs.com/26biketrials
dankearns13@hotmail.co.uk
cheers!!!!!
dan!!!!
Strip your rear hub, and double-check your axle isn't buggered internally. It could be you've broken the axle itself inside the hub, which would probably cause the problem you've said. Don't just rely on the "shake test" either, really strip it down.
