Sony Digital Handycam?
deanie-b
Lol, ok. This is assuming your running Windows XP. I'm not sure if it's the same for other operating systems.
Click start-->run
Type "diskmgmt.msc" without the quotes
In the window at the bottom, see if you can find the camera. See if it has the same drive letter as another drive (such as a hard drive or something)
If it does, right click the icon-->change drive letter and paths-->click change in the window that pops up, then change the letter to something that none of the other drives will have...such as q.
Then press ok to the messages. Hopefully now you can see the camera in the My Computer screen.
If not, you're screwed :)
god knows what i'm doing up at this time hehe, i had the same problem. follow these steps and it should work.
1. turn camera on and go to play and edit.
2. click on p-menu then click on standard set.
3. scoll down until you get to usb-ply/edt
4. open this then click on usb then i should work.
but my camera is only a few month old so the set up may of changed. these stems are to reconise the camera for usb streaming so it stil may not work. but though id try and help. (Y)
cheers..
Edited by lewis
