Is My Chain Too Tight
Shez.sheridan
I run a Monty mod with a profile hub. I bought my bike last year off a guy who'd jut fitted a new chain..
Originally as you can expect, there was an acceptable amount of chain slack, although now (probably after the chains stretched a bit) it had got to the point where you could touch both sides of the chainstay with the chain, at the same time.
To resolve this, as the engagement is still good, but not as immediate as it once was; I moved the wheel back a tad with the monty tensioners (by one notch each side)..now I'm not too sure whether it's over tightened.
The engagements instant i.e. the chain is tight, I can only push it up 10mm max with my fingers..& with my hands, if I spin the cranks as fast as I can, it will only backpedal just under 2 full crank revolutions before it stops. However my profile hub still runs fine (although I'm sure there is a larger load placed on it)..
Is this too tight?
Cheers Derv.
Or a cassette hub :rolleyes::P
10 mm is good (Y) at most id say 15mm and min would be about 7mm
Although at the moment mine is like 2mm lol
I generally do mine up so that I can *just* touch one side of the chainstay. But I've run it looser than that with no problems (you get used to it after a bit, I'm not too fussy on bike setup to to be honest as long as my brakes lock...)
And for those who run their chain well tight...I bet you go through more freewheels in a year than the rest of us ;)
I also find it harder to align the rear wheel properly when I've got a chain at ridiculously high tension.
Just my 10p.
Hey well i was running mine majorly tight (like the cranks span while i pushed my bike) then my freewheel split when i kickhopped and i could just watch the bearings pour out. so just make sure ur not running it to tight. Ive gone from one extreme to the other as im now running a super slack chain. :huh:
cheers joe
