Help! 4 Bolt Mount Problems...
SAMWELL
Hi
I have a problem. I got a 2nd hand frame off someone recently. It wasnt too old. The 4 bolt mounts on one side had been stripped so either himself, or someone else, had attempted to helicoil the mounts. They had done a shoddy job and when I went to put a bolt in, they went in at a nasty angle and one came out it was so loose.
I decided to redo the helicoils but obviously, there wasnt enough thread for the coils to lock on to.
I tried filling the hole with metal putty (JB Weld) and drilling again, but it didnt work at all.
Im kind of lost for ideas now, I could weld the hole up with metal but thats a lot of hassle. I dont like the feeling im stuck here with a useless frame :unsure:
any ideas?
hmm interesting
but i need to make the m4 bolt size to fit 4bolt mounts and 4 bolt booster spacers
i tried another method tonight, just about given up. might just have to take it to be rewelded :angry:
If you can't do the m4 size you could always go one size bigger and just drill your 4 bolt mounts and booster to fit
Im at size M6 atm - i think. m5 was originally drilled for the correct helicoils but now its m6, if anything.
Also, the booster i will be using has spacers, like others. They cant be replaced so easily, it would be just more of a hassle.
That link was useful thank you tom, although ive already tried the metal paste mix and it doesnt hold anything. I drilled it when i tried, then when tapping, it turned into chalk. And ive been told i was using the best stuff!!! (someone apparently glued their brake LEVER with it)
