Echo Rim 2006
hi im riding my adamant tomoz but i need to do sum stuff to echo rim first as its new
can i jus rub the top layer of anodising off on the braking surface as i dont want to grind this 1 yet
The best way is to get a old disc and use that to grind it of so u dont get all the s**t in it,and then use a new disc to grind you rim (Y)
cheers danny ^_^
if your using a 4 inch grinder then all you need to do is buy a backing pad and some sanding disks, i wud suggest 60 grit. the backing pad and the front screw bit enables you to run sanding pads on small grinders. if you get a backing pad from say dixon halls or some other decent power tool place and some sanding pads, 36 grit being harsh, 60 being smooth, you can sand the anodised coating off without grindin your rim
