Getting So Many Troubles With Maguras.
aaron-i'anson
Hi, I'm getting so many problems with my Magura. I run front and rear, Both bled with water but its always my rear one what f**ks up. Nothing on the brake leeks its all good but what keeps happening is, The slave cylinder on one side returns really slowly and makes the brake drag really bad. I have tried to resolve this problem so many times bought a whole new brake and even bought just slaves on their own but, Nothing helps its after a few weeks it just starts doing it again all my other riding friends don't get it but i do.
Can anyone help please would be appreciated loads.
cheers Aaron.
Have you tried lubing the pistons up? Just take the wheel and pads out, get someone to pull the lever whilst you cover one of the pistons with your finger (so the other one pushes out further), then spray that with GT-85. Pump the lever a few times, wipe it clean, spray again, then repeat that until it stops coming out all skanky. Do one more spray with GT-85 to lube it, then do the same to the other side. It's always sorted it for me (Y)
Thank you, I will try that where can i get hold of GT-85 Mark?
