Help
Sam Ward
Well somehow one of my brake bolts has rouded itself off, ive searched but all i get is superglue an allen key in but its too late to buy superglue.
ive also tried to use a torx key but i cant find on the right size.
so it needs to be set up, or atleast tightened by tomorrow morningso i can have my pictures taken with it.
but i don't know of another way to sort it.
could you please suggest a way to sort it please.
sam
Thats the thing, i also cant get the bolt out to use the ones i had, a friend has them now.
how would i tap the fitting bit???? :blink:
sam
Another bodge you could do; I doubt it would work but you could use a hacksaw...wait for it... and cut a 'slotted head' screw head in it; then tighten/loosen using an electric screwdriver
cutting a slot is your best bet (Y) just to fit a flat headed screwdriver-if you have an impact screwdriver use that :)
well sawing it didnt work so now im really buggered.
my holidays are royally screwed up now, i really need a suggestion.
or do you think a bikeshop or mechainc would be able to sort the fcuker out because i sure as hell cant.
sam
i would of suggested the groove and phillips screwdriver bodge too, but i guess that ain't working so the only other thing i can think of is file the bolt down on two sides and get a small spanner or pliers and get it of that way,
kinda like this:
[attachmentid=5035]
kinda like this:
[attachmentid=5035]
That is the way to do it... i did my maggie bolt like that after rounding it completely. I used an angle grinder though because i'm too impatient to file it. And if you have some use them mole grip things to clamp onto both of the flat sides of the bolt, they'll hold it much tighter than a spanner will so you'll be able to twist it even more.
I'm still running my bolt like that after doing it about a month ago.
These are mole grips if you don't know what they are IPB Image
