Is Tar Good For Using On Your Wheels?
g4ngst4_s4m
i was wondering if tar was good for on your wheels to help brake ?
i know this sounds stupid but i thought it whould be funny to tip coke on my mates front wheel and it gave awsome brakeing power
and you can bye spray on tar off cleanbikes.co.uk (Y)
Edited by phil_williams
If you put a sinsible amount on it works really well. Just don't go colouring in your rims like you a 4 year old with a wax crayon.
Spitting on your disc, big no no. You'll get it contaminated, a disc should really be powerful enough as it is, chucking water on it generaly sorts out any power issuses, but it shouldn't be done every day, should only be done once when you first get it.
(Y)
I've only tried tar once but IMO it does give a stronger grip at the expense of modulation. If I was going to use it I would probably only use it on the rear wheel, as the rear wheel is required to lock reliably and not slip.
If you want to do stoppies then I imagine tar on the front wheel would make it harder due to the wheel locking.
Likewise if you have tar on the rear I imagine manuals would be harder to do as modulating the break would be harder. (N)
Like I say I've only tried tar once so I could be wrong. (Y)
I think the common misconception with tar is that people coat their rims in it and then the pads stick and they cry.
I put a really fine line of it round both sides of the rim an then the tar just smears out how i like it.
imo i think it gives same amount of braking power as my mates plaz's on his grind, havnt had any slips yet so....
just dont ride in the rain :S
Ive ridden both a mod and a stock with tar on the front (both unground) and imo it gives the feel more like a good hydraulic disc brake e.g the hope moni mini trial. Comparing the price of a good v-brake (deores are good enough - £10) with the mini, its quite clear that a little tar can make a big difference, not only in performance, but also in cost too ;)
