Help
<_< its a FIXED hub which means u have a FIXED cog on the hub eg 12 tooth . IF you have a 12 tooth on the back you must have a freewheel on the front. you now need a set of cranks with a thread on . you also need a 127.5 or bigger bottom bracket. check the echo site for all what u need
i run
an echo front freewheel bottombracket
an echo green fixed hub
an echo 12 tooth fixed cog
tensile cranks (with thread)
and a normal freewheel
i run
i think hes running a rear freewheel
John kan the china man
yer he is running a rear freewheel but thats what i said they are FIXED hubs whech means FIXED cogs only there isnt enough thread for a freewheel thats why they are made
Actually, you can run either a cog, or a freewheel, as long as the threads are the right size. Fixed just refers to the hub itself, rather than a freehub, such as a profile.
Although, im not exactly sure what the problem is. :turned:
Edited by Hobnobs
  • 2 weeks later...
