Wheelswapping
Ollie Y
hello guys and girls, ive been trying this for ages and i just cant do it, i think its called wheel swapping
(when you do an endo and flick to backwheel) i keep tryinging it on flat, i can get from front to back but i find gapping to front wheel hard and not quite sure how to do that and then switching wheels harder i cant get the back wheel to where the front was, how do u get the motion forward? cheers
Edited by oliyoungman14
Hey,
i'll explain.
Try riding up onto a curb face on and pull an endo, now your weight is over the front (shagging the stem). As you let the front brake off throw the bike between you and put all your weight over the back...
After that try maybe pedal hopping to front with a bit more speed, after doing that try static hop to front and you should have the basics sorted..
Hope that help? (Y)B)
Dan
hey (Y)
what i did first to learn how i got from endo to back wheel was i pressed both brakes at the endo and just pulled back into a wheelie position , try this for around 10 minutes to get used to it and practise untill you get perfect balce then learn the basic pedal kick in there to help or hop
hope it helped !
mX
Hay
the other week i tried to do that wheel swapping and couldn't do it, so i looked on trashzen.com and next time i was out nailed it! thats on the flat though haven't tried going up some thing yet.
highly recommend www.trashzen.com its brilliant
(Y) hope it helps
chow :deej:
