What's The Difference
nig@hulltrials
  • 6 months later...
hi mate about 4 months ago we were chattin about u sellin gme a set o forks and then maybe some cranks and a gu bash
well i am sure u never sent he forks and i decided not to buy the cranks as i ran out of ime, can u please message me back asap
cheers, as i have paid for a set of forks and have nnot got them
Adie
ti is stronger but lighter, not much in it really
pr
Wheelbase: 1000mm
Chainstay Length: 362mm
BB Rise: 50mm
Head Angle: 72 degrees
Centre of BB shell to top centre of head tube: 605mm (23.75")
ti
Wheelbase: 1005mm
BB Rise: 50mm
Centre of BB shell to top centre of head tube: 600mm (23.6")
isnt it obvious?
And the kid has a PR.
no, It's still not clear to me how wanting to know the differance makes him a homo.
will you explain it for me please? I'd like to know the link between the differance of monty's and homosexuality. Im looking forward to your reply.
So am I , this better be good...
They are fairly similar looking frames but they are quite different to ride or so I'm told.
Montys ARE gay.
there we go :P
The Ti has triple butted 7005 alu. Almost every piece of tubing is different on the Ti,
the headtube is bigger for internal headset,
the downtube ovalises at the headtube weld rather than the PR that has a gusset welded
The chainstays are welded all the way around the dropouts,
the plates that are welded around the seat-tube are welded on differently on the PR
finally the only other thing I can see is that the toptube and the downtube on the Ti join the headtube together, on the PR there is a space between them.
As said before the Ti is disc only. Or more simply just read what Adam said.
