Loose Disc
Blommah
Yeah quite a bit but i bought new bolts and now its fine,
so super glue or new bolts, if you buy new bolt buy Allen key bolt as there less pron to round off
plus like 90% of trials *riders carry Allen keys round with them so would be no trouble to titan again!
cheers tyler .
Edited by Xx-OnZa-xX
i just loctited mine on.... when it came to taking it off it just cracked loose then screwed out fine! just do that!
Hmm, i got locktite-superglue, but no loctite-threadlock and i dont know if i have the time to buy it, i wanna ride asap, think i`ll try loctite-superglue.
The disc came loose last time with loctite-threadlock.
cheers tyler .
You may want to rethink that, the name torx gives it away alittle that you can use more torque on them so you can get them tighter as they are less likely to round off. Like everyone else said loctite is a easy way of solving it. Or get decent tool and tighten them up tight dont use the crappy tool that usual comes with it.
Ha ha, i was going to say something about allen key bolts being super easy to round.
My disc has never come loose. Get a T25 drill bit, place it in one of them interchangeable headed screwdrivers with a rubber handle, put your gloves on, twist as hard as you can.
My T25 drill bit has been twisted round slightly (its like a spiral now :lol:) without even a hint of the bolts rounding.
