Brake Pads
It is all dependant on your set-up of your bike.
If you've got smooth rims then some standard or soft pads with a bit of tar will do.
If you've got a grind you need something a bit harder to stand up to the job.
I recommend Magura Kool Stops for a smooth rim if you are on a budget, they aint bad pads. £15 for 4 pads is pretty cheap as well (www.chainreactioncycles.com).
Edited by thutley
:o don't get kool stops...just pay the extra £3 and get some zoo! pads when they come in stock at tarty if your running a smooth rim. If your running a grind i've found koxx reds to be quite good, rock pads are fairly amazing and emmit a rather loud squeking noise. (Y)
first of all mate learn to spell correctly or use the spell checker. zoo pads are very good along with plazmatics. i would use zoo pads for a smooth rim and plazmatics for a grind.
cheers lou.
Say's you !. I have put your mistakes in Bold for you. So you learn how to punctuate first.
Zoo pads - Smooth rim.
Rock pad Blue's - Ground rim.
Dan.......................
Now, now Danny. What happened to the exclamation mark after Zoo ?
Was there really any need to use a capital 'b' for blue?
Anyway, Plazmatic CRM's work well on a light grind, as do pads from the Heatsink range. www.heatsinkbikes.com
Edited by max-t
There are a few topics on this but I can't talk when it comes to making new threads(sorry) LOL!
Anyway I have heatsink coust pads (green) and there really good, I have a light grind/stanely knife grind. (I did use an angle grinder but I couldn't get the tyre off so didnt do a good job) :(
~Matty :D
