Recommend Me?
fathopper
I've got an avid ultimate vee on the back, and it seems my pads are wearing unevenly due to slight flex in the arms from the posts, could anyone recommend me a booster which is roughly 120mm/12cm if ive got my measurements right?
The Shimano XTR booster might do the trick,not sure where you would find one though.
Have a look at this one, theres a few others on CRC aswell. http://www.chainreactioncycles.com/Models.aspx?ModelID=8215
This one maybe abit narrow, but have a look anyway. http://www.tartybikes.co.uk/product.php?id=13
Or give BETD/Goltec a ring. They might have a few of there's left. I'm running one on the back of my Giant Team trials with a HS33 as the frame uses v-brake bosses, not 4 bolt mounts. It's fantastically stiff, as the back end of these flexes like a b*****d as standard!
Give them a ring and see if they have any left. The one thing you will need to check is the gap between your brake bosses, as the boosters use holes instead of slots. Mine measures out at 85mm, but it'd be worth giving them a tinkle as i think they did some different sizes. And as it's BETD stuff, the finish and quality is excellent. If there's one available for you're setup, it get's a big (Y) from me, and I urge you to get one!
Smithy
