Grrr... Stupid Tight Cranks!
Jonny Shoe
Hi,
I have now been trying for half an hour to take the monty cranks off my snapped T-pro frame, with no luck. They are square taper, therefore I have been using a crank extractor but however hard I try I cannot get the cranks to budge. Does anyone have any fantastic ideas how I can take these bliddy things off, my next move?
Thanks
get some Plusgas (or any other penatrating oil) and spay aload on the area. Leave it for a good few hours, then give the crank a good thwack with a rubber mallet. Then try with the crank extractor. that might work.
The easiest way to do it is to warm the crank. Twatting the hell out of it will probably bend the BB axle, and I doubt the taper is corroded to the crank so penetrating oil is only half a cure. Get some tension on with the puller, then warm the crank up with a blowlamp. Try not to get too much heat into the axle, and it should pop straight off.
The recovery stages of annealing aluminium occur from 100 celsius upwards, and even then, the grain size remains similar and the dislocations decrease slightly. I said warm, not blast to hell and back again, intelligent use of a blowlamp works, as does boiling water if you're not too happy about gas torches. The last one I did this way could still be (uncomfortably) touched by hand, so the temperature was nowhere near changing anything.
bloody hell youve made me feel stupid now lol
