Echo Messurments?
Smallville
if you have the hub you could try measuring it?!?
Well, I dont have the hubs yet thats why I would like to know so I can order spokes.
If you have the hub measure the whole flange and then just half it. You should be able to get it fairly acurate.
Dont know if I understand you, but if I want to know the diameter of the flange why should I measure it and the half it?
where are you ordering it from? if its tartybikes then tell them what rim and spoke pattern you want then they'll calculate the spoke length for you and send you the right spokes!
simple!!
dunno about other companies but try ordering the hub and spokes together and explain in the comment field which rim you have etc
^^Second! I always just ask the shop that sells the hub for spokes. Even if you're not buying them together Tarty should have no problem pulling out the right spokes for you.
Tarty gave me the measurments for the hubs. They would have helped me with spoke lenght if they could, but I got Zhi rims and they dont know the ERD for them. Now when I have the hub measurments and I measured the ERD my self (bit tricky to get that exact) I use DT spokecalculator and Im just fine. Seems like 264mm should work both sides, front and rear.
you could measure the erd of your rim because you're gonna need it soon anyway!
