Question About Leesons And Pashleys?!?!
NVWOCI WVS
hi, does anyone know what grade steel leeson and pashley use on their frames?
and also what type of welding they use?
this is for my a-level tech...designing a new trials frame and thinking of trying to find an old steel frame to modify as a donor-bike.
so also if anyone has an old steel trials frame lying about that is damaged/unrideable/extremely cheap i'll be interested!!
I'll put an ad up in the for sale and wanted section at a later date but just really the question for now, thanks.
sam
sam
Leeson use Reynolds 725 and I think Pashley use Reynolds 531.
I think leeson braze the frames, may be wrong though.
ok, thanks...thats really useful.
do you reckon i'll be ok brazing my frame...i cant weld very well but i can braze ok and i'll practise before going to the frame!
erm yeah, so will brazing be strong enough??
cheers
Leesons are definitely fillet brazed. I think there done the same way as my Iolo where an inner brazed is formed at a high heat, and them a lower heat fillet braze is placed on-top to smooth it off and help dissipate the stress. I'm pretty sure Pashleys are TIG welled, they sure as hell look it anyway.
Brazing is plenty strong enough. Leeson Curtis Iolobikes and fresh products all use it. (Y)
Were Pashleys not a mix of steels?
Im sure the front triangle was 853 reynolds and the chainstays were 531.
EDIT: my mistake, the Pashley was made of 853 and 725 reynolds
Edited by bob87
Pashley used to use 531 but now this materials is at the end of the production line because as you should know reynolds have realeased 953 quite a while back so pashley willuse 853 or 725 (953 is too dear at the moment)
T45 and good old 4130 are pretty common grades of steel used as well. Reynolds website has some info about their different grades of tubing and allowable manufacturing processes. Have a look at iolobikes.com, and contact them, I've been looking at custom frames and Aran had loads of time for me when I phoned, and was happy to talk about construction materials and techniques.
QUOTE(Bill_B @ Apr 24 2007, 10:29 AM)
thanks,might try it.
reynolds can only supply butted tubes apparently, so i cant use their tubing anyway as i require plain guage.
