Chain
can any wone haip me i was Tampering with my Chain Tensioner and i was wondring if there is a way of running no Tensioner
yes if your chain is fully stretched and had a certain gear ratio and certain chainstay lengths.
not many people do this though as its hard to do.
Edited by Grant H
bmx puts just as much pressure on the wheels.
i thought you meant you were riding a 20" so you had horizontal dropouts and them tensioners that hold the wheel in place. if however you ride a 26" stock with the fixed dropouts its not worth trying to get the chain to the right length to not need a tensioner as it just makes getting the wheel out harder as you would most probably need to split the cahin to get it of unless you run it slacker than an amsterdam local worker
