Front Freewheel On Stock
Im just wondering about running a fixed hub on rear, some front freewheel - probably Tensile, and a Rohloff chain tensioner.
Will the chain tension be ok and aligned easily, and also with Tensile cranks, will I still be able to have a bashguard and a freewheel?
Lastly are there many stock riders with front freewheel?
with a freehub its very rarely the whole thing that breaks though.
id go for a freehub, just avoid deng ones.
mike ;)
mike ;)
what if he's using a 116mm spaced frame
and its cheaper if it goes wrong (replacing a tensile would be 35 quid, instead of 130)
Did'nt mention anything about 116mm frames you pillow.
And the price thing as a whole, fixed hub inc would come to a similar price, stop arguing , you brought a pro 2 over this idea you hippocrite.
Edited by afroman
yes but he didn't mention about 135mm...
I got the pro 2 because i didn't want to get cranks etc.
It's 135mm axle, and infact if I get front freewheel I think it'll turn out more money as I'll also need bashring, rear sprocket and I don't know any problems linked with the chain tension and alignment.
I also haven't heard a bad thing about the Pro2, so I'll save the front freewheel for some wintertime.
if you want front freewheel on a stock you have to have tensiles (or some other cranks that will allow a freewheel and bashring)
i was going to buy some with a bottom bracket then i saw a pair of tryall rims on pro2 07 for £10 less
so got them, now i wouldnt change for any sort of freewheel becouse the pro2 sounds great and never skips!!
Hope will repair (service) for free but if you want the internals replaced it will cost £30.
Pretty sure its free. Especially within the first year of riding a pro 2t.
If its an XC/mono then yes, you'll have to pay £30.
Bikes with 116mm dropouts don't have mech hangers. Rholoff tensioners mount on the mech hanger.
