Side Hopping
The best way to sidehop, i found out is to, get on to your back wheel, stay parralell to the wall at all times.
look at the part of the wall you wish to place your front wheel on to.
lower your front wheel about 1/2-1ft and then just stomp on the peadle, place your wheel on the wall, and then just tuck up with your legs and your back wheel will follow on to the wall....
hope iv helped....
...Shaun...(Y)
sometimes I have problems side hopping just asking how do you side hop and pictures if you can. I sidehop using my front brake.
thanks
hi you can use your front brake really side hops are not that hard it is just being able to get the right angle once you can do that try not to hop on your back wheel to much just bounce a couple of times and bounce lifting your back wheel up to you moving to the side making sure you have got your front wheel above the wall or what ever you are side hopping up.
from mitch.
from mitch.
so what happens when you sidehop more than about 30 inches.
