Gravity Defied - Trial Racing [gdtr]
J-Gill
just seeing if anyone has been playin this game? http://www.codebrew.se/gdtr/?s=home i've been playin it on my k700i and it has been a god send for when i'm waiting for trains,etc. On the web site you can only get a demo for free, but after searching the net high and low i found it for free. :P http://maestro.intramail.ru/files/java/index.php?name=G when usin this site you have to download them to your desktop and then i send them to your phone. i use an infra-red port on my laptop to transfer the file to my phone.They can also be sent to the phone by USB cable and Bluetooth if your computer has it.
be warned it can lead to your thumbs hurtin from playin it.
How did u get it to work, as i have downloaded it, but i don't know what i have to do to get the game to work on my phone, thanks.
Adam
go to applications on your phone.. it should be located there... and install it from there.... if you cant see it.. youve placed it in the wrong drive/folder on your phone... are you placing it on your MMC or device memory ?
It saves it direct;y into my gallerys folder..no option for location of saving and doesn't show where you say it does
You need to use the nokia communication suite software to install it, then it should be under apps. From the sounds of it you just tried dragging and dropping it?
you don't...... and yes you can get it to work by just the drag and drop method... i have an n gage though.. which tends to work a lil different to other nokias... but yeah.. dragging and dropping should be sufficient as long as its dropped in the correct place
You do on the 6230 iirc because its crap
