John Shrewsbury's Leeson
DaiTrials
Yo John, if your online and not riding :P
Just wondering what your running, gonna be gettin a 24" soon, Just saw TM2 - awsome riding and lush ride!
Main query is what forks are you running, what bar and stem ( bar length / cut down ?? ) and what tyres you are using, thankyou
DaiTrialz
Edited by DaiTrials
Here's a pic:
IPB Image
Different paint job since TM2, I guess it's been back for repair or something. Looks nice now I reckon, I was gonna get a green one.
Anyway: Forks look like modified pashleys, tyres are both tiogas. Front looks like a Comp III, back one is probably a Factory DH. I wouldn't recommend them though, no matter who uses them :P
As for bar and stem I'll let someone else answer because I can't see from the pics. But the stem looks like an Easton.
Ye, pashley forks, extended steerer tube I think? cos he has loads of spacers on there. 2.5" rise azonics, singlewalls cos doubles are well shiny? :ermm:.
And shit tyres, comp 3's are ok, do the job, but I pinched a rear 'DH' :S one about 5 times in a day, running it about 40psi and I weight about 5 gramms. get a maxxis anyday, think there about the same price...
The Comp 3's from CRC are so much narrower than the other Comp 3's from where ever John gets his from, even though there both meant to be 2.1" try and get a fatter one, cos the one I got from CRC is really really narrow and rubbish for taps etc.
LEESON FRAME, 1030 LENGTH
FORKS PASHELYS WITH MOUNTS ON BACK, v brake works so much better without grind.
BARS DH 2.5 rise azonic single wall.
I've always run tioga DH tyres on the rear ( Shit grip in wet, but gd in the dry)
COMP 3 TIOGA TYRE, for the front in 2.1
STEM just a normal rise stem, short and sweet. If your wanting a gd stem, look at the new HOPE
STEMS, just get a gd rise one.
CLIVE LEESON mostly helps me out with the frame and forks.
shewers (Y)
shewers (Y)
While you're here, how do you find that back brake on the back of the frame thing? Must be a bitch to set up?
As for cutting down bars, I run some cut-down Eastons on my Ashton and they're ok. I'm not really down with the whole wide bar thing, I never found them to help. At the moment mine are pretty narrow (25" ish) and I can do everything the same. The only real advantage that I've noticed is with X-ups, but that's not exactly important. It might help for manuals too, but I am crap at them anyway so I couldn't tell you.
just make it more efficient , and yeah pace made reverse mount 26" forks , not sure if they still do , if not clive will make some for you (Y)
For all you mathamatitions if you imagine the wheel going forward and the brakes mounted normally, then the force on the brakes is pulling them off the forks. by mounting the brakes on the back of the forks then the force acting on the brakes forces them into the fork, and so the brakes are stronger. This is why a rear brake is better mounted ontop on the stays rather than underneath (same reason)
Did I just answer a question in my own topic? lol
PS - john, what width are those bars man, i know its up to prefrence but theres gotta be a nice length to suit 24" style and you must of been tinkering for a while :)
Edited by DaiTrials
I got clive to put the mounts on the frame like that, as i've seen bmx frame's hav the same thing and wanted to try sumthing diffrent, it does work, but not as well as i fort it wud.
I think the lenght of my bars are 27. (great lenght), so i find it really easy to x'up and there a DH bar in 2.5 rise. I use 28 length bars on my 26inch bike, so not much difference( just lower rise)Just feel's like a bmx really.
Edited by John Shrewsbury
Bmx frames have the brakes there to deal with chain clearance issues. Which most get round now but welding the stays lower. Can't see any benefits for trials.
What reasons made you think it would work better?
All i had done was mounts put on, Hasn't afecked the frame in anyway, just wanted to try it out, to see if the brake wud work. One thing which was gd about it was, that it was easyer to set up that way.
Maybe hav the brake down the bottom for my 26inch next time.
Chainstays are generally a bit fatter and presumably stiffer than seat stays. I guess that's one potentially good thing. On the other hand it would be hard to set up and you run a greater risk of getting oil all over the pads...
But why? i mean if theres no real benefit whats the point. I always find bmx's with under seatstay brakes a pain in the arse to set up.
"Don't fix what isn't broken" - Some wise bloke. :)
Didn't Leeson have a proto like this though and decided it wasn't viable. Your right on the Oil score also i'm sure the crossover would get in the way.
Mr Margaret Thatcher :D
I think so, yeah. And on that funky one-tubed Giant trials frame.
Just wondering, isn't the whole point in having a bespoke bike to be able to choose your OWN geo?
By looking at the post John might as well start building up aload of the same spec'd bikes and selling them fully built for a small profit! The whole idea is that John is experimenting with his own taste, not someone elses to get the perfect ride for himself. By copying his geo you may get a bike that rides amazingly, for John, but for you it could be utter balls because your not John! Just go on a bunch of different peoples bikes, think about what you've ridden before, change some bits about on your current bike and see what difference it makes.
Just my opinion but a viable one I think?
May get slaughtered but meh, don't really care.
