Stock And Mod Pro's And Con's
Jacko.
Hey, i see allot of topics about "what is best Mod or Stock", so i thought i would make this topic to show what I think the pro's and con's are.
Mod
Pro's
Great stand over clearance
Very "flicky" rear end good for gaps
Cheaper parts
Stronger in the long run
Good for side hops, no derailleur problems
Con's
Can be less comfortable
Less parts available
Not so good grip on small wheels
Stock
Pro's
More grip on the larger wheels
Can be more comfortable
Good balance and stability
Less chavs :- asking you to go and do a barspin or grind something
More parts available
Con's
Not as reliable
Many parts to break
More expensive
Derailleur can be a pain, easy to hit on things
Rims are easier to get flat spots dents or what not
Quite substantually *sp* heavier
Add anything else you think may be helpful to others.
Jacko (Y)
Its on biketrials.com so i thought i would add it. Its abit outdated though but, meh!!
Choosing between stock and mod
Both modified and stock trials bikes have pros and cons:
Modified (20" wheels)
Pros:
Superb standover clearance
Easily manueverable in most every circumstance, especially anything rear wheel
Less expensive
Less parts to break
Nearly impossible to bend the rim of a well-built 19" rear mod wheel running enough tire pressure
Learn to sidehop up to both sides without worrying about a rear derailleur
Cons:
Some people may think it's a BMX bike
A pain to ride more than a mile or two on
May be harder to find parts for it
Harder to roll down things
Easier to go over the handlebars (but less scary when you do)
Doing wedge or wheelbase moves is less comfortable
Stock (26" wheels)
Pros:
More stable
Bigger wheels = roll everything easier
Easier to do wedge or wheelbase moves
Easier to pedal-kick on odd surfaces because of the larger diameter wheel
You can ride to your riding spot easily (if you have a seat and working gears)
Looks more like a mountain bike
People won't ask you to "grind" stuff or think you do BMX vert or street
Cons:
Bigger bike = less standover clearance = pain if you fall on the bike
Easy to hit knees on top-tube of most bikes
Less room to work with for bending down before sidehopping, bunnyhopping, etc. or when absorbing landings
More expensive because of greater frequency of breakage and more parts to break
Rear derailleurs - easy to smash into things (though most bikes have replaceable derailleur hangers that will bend before the derailleur is broken)
Wheels - 26" size = easier to get out of true or taco (20" wheels are extremely hard to ruin when built and used properly)
Chain can slip down or up a gear while you ride if your chain is too loose, or you smack your derailleur in section and break it
Heavier
Gav :)
