Gear Ratio's
Reece B
well the other day i got a middle burn 16tooth bash, and after reading on here, i find that 16:14 is the norm.
but ive switched from 22:17 which is pretty hard compared to 16:14, and i cant seem to get up stuff as easy:S
so ive tried 16:13 which is ment to be like 22:17 right?
i cant decide if i like 16:14 or 16:13, i like 16:14 it make the bike feel flicky but i cant ride as well.
16:13 i can get up walls but the bike feels like a tank:S
argh i just need some opinions
and abit more riding with the two set ups i guess
cheers Reece
Edited by Reecerazor
Ok, so, you've come from riding 22:17, which, as you've also said, is a relatively hard gearing (22/17 = 1.29, 33.65 gear inches)
16:14 = 1.14, 29.71 gi, which is a fair bit lighter than your previous ratio, explaining the way it's flickier, but also why you feel it's harder to get up stuff now
16:13 = 1.23, 32.00 gi, still lighter than your previous gearing, but far closer, and will make ups a bit easier again (whilst losing a bit of 'flick' remember though)
16:12 = 1.33, 34.67 gi, higher than 22:17, but a touch closer than 16:13
I'd suggest playing with 16:13 and 16:12, and finding which of the two you feel more comfortable with. Chuck one on, and ride with it for a while, then you'll have a better idea if you do want to change at all or not :)
Hopefully that hasn't been too confusing, but if you want anything clarified just shout :)
gear inches (Y)
least someone knows what they are on about.
i know some top top riders that run 16:14 and they can ride amazing (as in uci worldcup riders). What length cranks are you running? This can affect how the gear feels for example i'm running 18:15 with 175mm cranks but a mat of mine is running 170mm cranks with 16:14 gearing, makes it about the sameish. -Hugh
well i found, 16:14 to easy, made every thing seem really hard, well just ups:P
ive had a play with 16:13 today and i like it, im running 170 arms.
although i do like 16:14 for front wheel stuff and gaps but getting up is just a nightmare lol!
