Chain Snap Stack
Phil H
I have replaced the chain links, will this be sufficient or will the rest of the chain be weak?
"A chain is only as stong as its weakest link!" Quote That Ginger bird.... someone..... anne??? i dunno
But if one link goes you can genrally assume that the chain is probably close to being on its way out!!! so might as well fix it propperly before you go to do something bigger and hurt yourself!
Beast ... are you ok though ?
Looks abit painful :P
Yeah was fine thanks, knee swelled up abit but wasn't a big deal. :)
Yuhuh, thing is it is a fat half link chain and is quite newish so im not 100% sure. I knew it was going badly as I pedal kicked to the edge and didnt keep the front up so I kinda think it was down to that.
What chain would you recomend?
cheers, Phil
cheers, Phil
khe collapse..
  • 3 weeks later...
