Bent Rotor's..
Nick Dale
Is there any special way to get a buckle out of a disc rotor? Mines not really really bad, but it is noticable and is getting to the "annoying" stage now :(
So what shall i do to get the buckle out of the rotor?
Bend it about with my hands?
Heat it up and then bend it about with hands?
What is the trick to get it nice and straight again?
Ta for any help!
I've not tried this too much, but get an adjustable spanner and make it so it's tight against the rotor and go around the rotor as if you would a wheel with a spoke key, just keep trying.
what he said! I done this to a shockwave "piece of shite!" I bent it out by at least 4 inch and it only moved 1-2 mm =O
The way to get a rotor dead straight, is get up some speed and hold the brake on slightly, enough to slow you down, but not stop, and hold it in the same position for a bit and keep pedaling etc. it worked awsomely for me. also if you havent hit your rotor, and its bent by itself, make sure your pads are level and the rotor sits parrallel to the pads. hope i helped
mines kinda bent itself back a bit. but i did wack it on a curb and it went straighter than what it was :D
but a new rotor is what im gunnu go for when i get the money. my rotors been wacked to many times to still be strong lol
